In range and coerce
I want to make a VI that will show me how many random numbers from 0-100 range should be generated. After that VI should draw a histogram, showing how many percent of numbers were from 0-49 range and how many from 50-99. There should also be two numeric indicators showing how many numbers were from both of those ranges.
I use "In range and coerce", but for example if I generate numbers: 78, 97,74;
First "In range and coerce" (50-99)" will show output: 78, 97,74, which is correct.
But second "In range and coerce" (0-49)" will show output 49,49,49 which I dont want; I just want to show in this example one zero.
After that I will connect both input to histogram, will be OK ?
See picture, thanks
_________________________
Rookie; LV 2011 on WIN 7
Message 1 of 20
(4,666 Views)
Hi hlod,
did you read the context help for InRangeAndCoerce? That would clear up your first qeustion...
Did you try the histogram VI without any InRangeAndCoerce? It's all you need...
Message 2 of 20
(4,653 Views)
If your only goal is to plot an histogram, use the histogram function from the probability & statistics palette :
Epictetus
Antoine Chalons
Message 3 of 20
(4,651 Views)
Wll I must show on histogram "how many percent of numbers were from 0-49 range and how many from 50-99.", so for this reason I'm using "In Range and Coerce Function". But I have problem which I already described.
Message 4 of 20
(4,644 Views)
Hi hlod,
read the context help for hsitogram!
Then do a simple computation of your percentage values from the given histogram values: percentage = (#numbers in range)/(#all numbers)*100%
Message 5 of 20
(4,639 Views)
Yes I know that but I have probelms, that from 3 input numbers,"in range and coerce" function make:
78, 97,74  and  49,49,49;
From 3 input numbers I need 3 output not 6 :/. If it's not in range, why than show 49,49,49 ?
After that I will make front side as this on picture
Message 6 of 20
(4,636 Views)
Hi hlod,
did you  read message #2? Then you would have read the context help for that function and in turn you would know, why it outputs 49 for your second case...
That's the way "In Range and Coerce" works... Well, this function has a second output. You could use that to count the numbers in the given range... But hey, it is all written in the context help!
Did I mention the context help before?
Message 7 of 20
(4,634 Views)
Yes I read it, but I cannont make VI as on picture 1 post up. (please look it), I need function "in range and cou.."
Message 8 of 20
(4,629 Views)
Hi hlod,
no, you don't need InRangeAndCoerce as was written before!
Message 9 of 20
(4,626 Views)
I really think you should not use the "in range coerce" primitive...
Is this what you're trying to get?
Epictetus
Antoine Chalons
Message 10 of 20
(4,624 Views)
