06-06-2012 02:56 AM
@ TiTou
yes but in this case I need % on histogram, not values
06-06-2012 02:58 AM
Do you need help from us to calculate a percentage or do you think you can do it?
Hint, in the example above the ploted data is H(x).
Epictetus
06-06-2012 03:16 AM - edited 06-06-2012 03:16 AM
06-06-2012 04:25 AM
First thanks to all your help.
I try like this, I think it's ok, but I don't know why "amplitude" not showing beetween 40-60;
For example if "number of runs" is set to 1, amplitude must be at 0- 50 or 50-100 and not 0-40 or 60-100, see on picture:
06-06-2012 04:42 AM
06-06-2012 05:00 AM
Don't understand what can I chance at properties of plot. I think it's problem somewhere else not at properties;
If I set "numbers of set" =1
amplitude must be always 50% (0-50 or 50-100) and count: 100
06-06-2012 05:02 AM
Right clic on the graph then play with X-scale properties :
Epictetus
06-06-2012 05:04 AM
Hi hlod,
- When you only have one sample in your data then I would expect 100% in one range and 0% in the other...
- Your question about that gap between 40 and 60: The graph is configured to show a bar plot. The bars have a certain width and that width is set to show a gap between the bars. That is the gap you see. To remove the gap you have to change the width of the bars - which is a property of the plot as I said before. Change the plot properties to have the nice plot you expect to have!
06-06-2012 05:38 AM
Well I don't see anywhere where I can change this "gap", I try almost everything. (see picture)
06-06-2012 06:14 AM - edited 06-06-2012 06:16 AM
Hi hlod,
The easy way:
I would suspect the plot properties are accessable through the plot legend. By choosing the lower right option of "diagram type" you get a bar plot without gaps between the bars...
The not-as-easy way:
You know there are property nodes for each item in LabVIEW. There are property nodes for plots too...
