In a case structure....
In a case structure.....
If temp>800 celsius, then
     pressure=100*e^(10t)
where t is time varies at a rate of 100 ms.
else pressure=10 bar
but t should increase gradully by 100 ms or 0.1 sec
Message 1 of 8
(4,254 Views)
This appears to be a continuation of your earlier thread: http://forums.ni.com/t5/LabVIEW/XY-graph-using-formula-node/td-p/1846609
Please stick to the original thread.
Message 2 of 8
(4,235 Views)
Why do you have two separate case structures, with the same selection logic?
The input to your express formula node is not wired.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 3 of 8
(4,233 Views)
This may help.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 4 of 8
(4,216 Views)
can you please explain what is the need of using date/time function and double penetration in the above problem
Message 5 of 8
(4,192 Views)
Accepted by Jathin
That is to calculate the the elapsed time. The first one takes the time when you start the vi, the one inside the loop takes the current time and the substract just determines the elapsed time from start. I assume thats what you wanted.
The double conversion (i assume) is just to avoid a coercion dot.
Message 6 of 8
(4,187 Views)
um, eh, um, er, um, did anybody.. um, huh huh, eh, am I the only one that.... um, ehhhh....  Smiley Very Happy
Richard
Message 7 of 8
(4,182 Views)
after seeing the solution ace presented I was able to re-read the OP and find every element captured.  Some magic decoder ring you have there ace!
On the other hand- remove both convert to doubles and see if you get coersion dotsSmiley Surprised
"Should be" isn't "Is" -Jay
Message 8 of 8
(4,139 Views)
