In Range Express VI
Hi ALL,
Need your advice. I attach my test vi.
For such situation, when the numbers keep changing, how do I ensure the beep is always activated.
I have use In Range but  this does not guarantee the beep.
Is there a better way?
(3,563 Views)
Hi Osman,
well, at the moment you check for a range of 1199...1200 but keep adding numbers of 0...10. So what's the probability to hit that check range with such numbers?
You could:
- use a bigger range of difference 10 between limits
- use standard functions instead of an express vi (it hides all the important information from the programmer)
- there are comparison functions in their own palette including "in range and coerce"
- use a small timer in your loop to prevent cpu hogging
(3,546 Views)
Hi GerdW,
Thanks for your reply.
You are right that I can open up the range. As I only need 1 beep, that would produce more beeps
than I require. If my beep is a wav file, I would have an echo. I believe this would also happen with
In Range and Coerce function.
Rgds.
(3,527 Views)
Accepted by OSMAN
Hi Osman,
From my understanding, you try to make a single beep, if number reach some levels.
Well, you probably try my attached screenshot to see whether it works.
Regards, Kate
(3,511 Views)
Thanks Kate.
Works like a charm.
Rgds.
(3,470 Views)
