12-26-2014 04:19 PM
Dear Sir,
Its not like that i am not trying anything here. I am very new to LabView. I tried in most of the ways but I could not able to fix the problem.
Do I need to have two columns in the text file(i tried like that also).
But I could not able see the graph plotting in the front panel.
Attached is the data which i need to be converted into waveform graph. Please help me out.
kjd
12-26-2014 07:21 PM
12-26-2014 07:32 PM
Here is your basic program (why do you persist in attaching a picture, instead of attaching code as a VI, or inserting a Snippet, such as this, which is both a Picture and code?).
As Dennis suggested, you should play around with the Read from Spreadsheet function. Write yourself a little routine with just the Path and Read from Spreadsheet function (elements 1 and 2 from the Snippet), and look at all the outputs. Do you know how to do that? Simply wire an indicator to each output. Do this little experiment, and you should be able to figure out why you really need to know what the LabVIEW functions actually do, and how to use them.
12-27-2014 02:48 PM
Dear Sir,
Thanks for the detailed explanation.
I could able to verify the output as you suggested with the help of indicator.
But, I could not able to see the graph. Do I need to have two columns.
The data which i have are the frequenices from the machine. Please advise me.
KJD
12-27-2014 03:10 PM
12-27-2014 03:56 PM
Thanks a lot to both of you. The way you and bob explained me helped me a lot. I could able to get the graph..
Thanks for your patience
KJD
