Import text tile
Dear Sir,
I have some text files which need to be imported to labview, so that i can use those signal as a input for my future project.
I have tried importing those signals using Tools --> Advanced --> Import strings.
But i am getting some error which i have attached.  Please advise me what needs to be done.
Also, let me know whether  i am following the right approach.
KJD
Message 1 of 16
(5,710 Views)
Dear Sir,
I got the attached from the NI Website.  But i could not able to find the Load/Save Signals menu in LabView.
Could You please tell me where can i find that.
KJD
Message 2 of 16
(5,698 Views)
LabVIEW SignalExpress is not the same thing as LabVIEW. What are you actually using? LabVIEW has functions for reading files located on the File I/O palette. You should attach a sample of the file of you want detailed help.
Message 3 of 16
(5,677 Views)
Next time, just link to the source.  The effort put into the picture gave us less to work with than had you done so.
You can go to Help->Find Examples and find some basic IO examples.  Or, you can do as Dennis suggested and show us the code you have so far and attach some sample data so we can offer advice on how to parse that data.
Message 4 of 16
(5,659 Views)
To get help on your code, we need to see your code.  Attach a VI (instead of a picture!), or embed its image in the message as a Snippet.
BS
Message 5 of 16
(5,616 Views)
Dear Sir,
Please find the attached for the VI and the text file which i need to be converted into waveform.
Please let me know, if there is any corrections need to be done in the VI.
KJD
Message 6 of 16
(5,541 Views)
This is clearly a class assignment which you should do by yourself.  However, I'll give you a little hint -- read carefully all of the Help for Read from Spreadsheet File (be sure to read the Detailed Help).
Also, when I asked that you attach code and not a picture, I did not mean "attach a picture of your code".  When you attach a picture, you basically ask those of us who are willing to help you to (re-)write your code for you, as we cannot execute or test a picture.
BS
Message 7 of 16
(5,520 Views)
Why do you think that you need anything more than the graph and Read from Spreadsheet File?
Message 8 of 16
(5,494 Views)
Dear Sir,
Please find the attached VI.  I could able to run it.   I have the attached the data which need to be converted using LabView.
Those are the frequencies from the machine.
I could not able to see the graph continously in the Front Panel.  Is there any problem in the Input File.
Please help me out.
KJD
Message 9 of 16
(5,466 Views)
Go read my previous response, where I hint what the problem is with your code.  If you need another hint, look at your text file.  Come on, put a little effort into this yourself ...
BS
Message 10 of 16
(5,442 Views)
