Import files and link them
Good morning everyone,
Beginner on LabVIEW, I need your help ! 🙂
I'm actually working on a little mission about a screwdriver system.  This system got two move sensor, and is link to a screen which can display the torque thanks to 2 others sensors during the test. These measures are saved in a file on the cumputer of this system.
I'm using LabVIEW in order to display the movement thanks to the 2 move sensor. I would like to save in a file these measures. (It's ok for this part, i used the block "write in a measure file"). But i would like to recover the file with the torque saved in the computer thanks to the system, and link this file with the move measures in only one file.
Obviously i would like to see in the file the torque according to the move. that's the objective. But i really don't understand thanks to which way it can be possible. I already tried to open the files thanks to LabVIEW, but without success, and it's worst if i want to link 2 files. I searched in internet but i didn't found answers. So I come to you and i hope that you can help me 🙂
I don't need to send you my code, i just got my 2 move sensors link with the block "write in a measure file". 🙂
Thanks you a lot in advance.
Regards.
ML
PS : Sorry for my english , i'm french and i don't speak a really good english, but i tried 😄 I hope that it's enough for you to understand the situation 🙂 If you have any question i'll obviously try to answer as soon as possible 🙂
(3,342 Views)
No, you don't NEED to send your code, but it would make things a lot easier.
Your chances that someone will respond with some meaningful example rather than some glibberish English text like this one increases dramatically if you add your existing code to your post. Smiley LOL
Rolf Kalbermatter  My Blog
(3,338 Views)
Well i understand, i can sec you my code if you want but i don't think that it will be really useful ahah ^^ i just want to know a way to find this solution 🙂 But ok i'll send the code asap. 🙂
Sorry then 😕
(3,322 Views)
Please attach it to a post. Sending code through private messages or anything like that is not appreciated by most people.
(3,313 Views)
