Import DLL with unicode in Labview
Hi all,
i am developing a software user-friendly to control a home-made microscope. I would like to install a Andor camera and to control it i have to import the dll of Andor SDK v3 but Labview cannot see any function from the header file because of a Unicode compatibility with LAbview (apparently Labview cannot read Unicode from the dll). Do you have any idea how to solve my problem ?
thanks
regards
Philippe
(2,971 Views)
The problem you are having is a limitation with the Import Wizard. You should be able to configure the Call Library Function Node manually. As for Unicode support in general, you should read this article: http://decibel.ni.com/content/docs/DOC-10153
(2,952 Views)
