Implement json web token JWT with labview
I need to implement JWT authentication with labview, how can it be done?
Message 1 of 11
(9,989 Views)
I guess you can try to play with this procedure.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LgPSAU&l=en-US
Any specific reason you want to use JSON?
Message 2 of 11
(9,946 Views)
My Labview applivation need to get data from another Oracle based application (Not Labview).
The data is available in a web service with JWT authentication, I also need to deliver data in the same way (web service with JWT).
I didn't find any labview based tool or (activeX, .net) tool I can use for encryption decryption JWT.
Message 3 of 11
(9,930 Views)
You will have to use the Import Web Service Wizard for authentication.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/platform/webservice/main-panel/main...
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
Message 4 of 11
(9,887 Views)
Accepted by topic author dor-s
I am not aware of an existing JWT library for LabVIEW. You can see from the JWT site that to creating and parsing JWT requires:
JSON encoder / decoder
base64 encode / decode
and a signature / encryption method (commonly HMACSHA256 built this depends on the Oracle application)
JSON encoding and decoding is available since LabVIEW 2013: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/programming/string/flatte...
The other two are not available from NI, but have implementations in the LabVIEW community:
Base64:
https://forums.ni.com/t5/Example-Code/LabVIEW-Utility-VIs-for-Base64-and-Base32Hex-Encoding-Using/ta...
https://forums.ni.com/t5/Example-Code/Fast-Base64-Encoder-Decoder-using-LabVIEW/ta-p/3503281
Signature:
https://lavag.org/files/file/198-encryption/
https://forums.ni.com/t5/Example-Code/Cryptography/ta-p/3494085
So unfortunately JWT support is not provided by default, but all the pieces needed to implement it should be there.
Milan
Message 5 of 11
(9,853 Views)
Thank you for the detailed answer, It seems like this is the best way to implement it.
Dor
Message 6 of 11
(9,787 Views)
I think JKI JSON is best fit for JSON serialization and deserialization needs with web services.
jki.net/tools#json
Tomi Maila
Message 7 of 11
(9,738 Views)
Hi Tomi,
Just to clarify we were discussing JSON Web Tokens which is used as a component of some authentication / authorization systems.
My understanding is the JKI JSON package just handles JSON parsing. It does not implement JWT / RFC 7519 correct?
If that's the case the JKI JSON package could be used for the JSON parsing, but there were more components being discussed in this thread.
Milan
Message 8 of 11
(9,733 Views)
Milan, sorry for confusion. I was proposing using JKI JSON as part of the toolchain in creation of JWT implementation for LabVIEW. LabVIEW native JSON is not very useful in libraries as it is strongly typed and usually you don't know the type of the data at edit time when writing general purpose libraries (such as JWT library).
Tomi Maila
Message 9 of 11
(9,716 Views)
Hi  dor-s!
How did you solve the signature issue?
Did you use HMACSHA256 encryption method or RSA Signature with SHA-256 encryption method?
HMACSHA256 is easy to do with the  libraries in https://lavag.org/files/file/198-encryption/ but I'm having problems with RSA Signature with SHA-256. Is there any library or VI for this?
Thanks in advance
Message 10 of 11
(8,334 Views)
