Image scaling
How to scale image independently for Height and Width using labview 8.5 software. Zoom factor is scaling 1:1. need to change the aspect ratio.. in my case need to change the width of the JPG image..
Message 1 of 9
(4,136 Views)
Hi Hari,
             You can use word Format picture VI
Thanks as kudos only:)
Message 2 of 9
(4,131 Views)
This knowledge base article may help
http://digital.ni.com/public.nsf/allkb/09F6A234EBFCDC7786256DDD0056668F
Message 3 of 9
(4,128 Views)
@ danil33..word format picture is not available in the reports pallete..it is available in  "Report Generation Toolkit for Microsoft Office " which has to be purchased are there any other vi's available..
@ Frabto..the second suggestion also scales with 1:1 ratio..
Thanks for your suggestions..
Message 4 of 9
(4,122 Views)
Hi Hari,
           Have you tried this:-
           http://zone.ni.com/devzone/cda/epd/p/id/2201
Message 5 of 9
(4,110 Views)
Yes,, I tried that earlier.. it too scales 1:1..
Message 6 of 9
(4,106 Views)
So what about zoom factor property ?
Message 7 of 9
(4,098 Views)
all the above examples use Zoom factor property..
Message 8 of 9
(4,093 Views)
It would require installing ImageMagick, but there is a LVOOP based library on the LAVA forums that can be used to manipulate images from within LabVIEW.
http://lavag.org/files/file/48-lvoop-imagemagick-interface/
http://www.imagemagick.org/script/index.php
Message 9 of 9
(4,079 Views)
