Image is getting right shifted
In my Front panel window i pasted one image through Edit --> Import picture to clip board .
When ever i run  this vi this image is getting right shifted by 1 pixel every time .
how to avoid this problem .
(2,591 Views)
Try this:
Select your picture and from the reorder menu reorder.PNG select "lock". This will lock the picture to the front panel.
Ben64
(2,580 Views)
Thank you ben.....
When i locked the image Its ok but while running the width of the pixel is decreasing by 6 to 8 pixels .?
When i stopped the code its comming to normal size again .
This shifting problem also is still continuing sir ?
(2,573 Views)
Without many details we can only guess what the issue might be. Can you show some screenshots of the front panel running and not running?
Ben64
(2,567 Views)
I assume the shift is happening when you change to run mode (ctrl-M) and not just when running. You could try turning the scrollbars off while in edit mode (right-click on them or use VI properties). Beyond this we'll probably need to see the code.
(2,559 Views)
