Image.cpp Line 12208 appears when using the "Print VI Front Panel" function.
I am using Labview 6.1 to build my application that graphs data and uses the print panel.vi for printouts. Launching the exe from the Windows Run Commandline it works fine. However, I am also using another Labview app(exe) to collect the data and once the data run completes I use the system Exec.vi to run my graphing program. It graphs the data but I get the following error; "image.cpp line 12208" . I do have Matrox Graphics G200 adapter and have tried the latest update. But my problem still exists.
(2,499 Views)
There is an on-line KnowledgeBase which describes these image.cpp errors and ways to work with them. It sounds as though you may have already seen this, but just in case, it recommends adjusting the printing options in the LabVIEW Edit » Preferences » Printing menu. This is used when printing causes this error. You may want to try this out and see if it helps.
J.R. Allen
(2,499 Views)
