Image Acquisition
Is there a method that allows a VI to get and display a file, specifically a jpeg image, on the front panel?
Message 1 of 8
(3,727 Views)
You can use Picture Control to display an image (bmp, jpg, and png).
Use Read Jpeg File.vi to load the file, and then use Draw Flattened Pixmap.vi
to display the image in Picture Control.
George Zou
http://gtoolbox.yeah.net
George Zou
Message 2 of 8
(3,723 Views)
I am very new to LabVIEW so what you wrote makes sense, but I am having trouble implementing it.  I placed the two VIs on my VI, and when I run it, I get a dialog box to select the image I want, but when I select it, I get an error at read JPEG File.vi.  What could I be doing wrong?  Thank you for your time.
-Tek
Message 3 of 8
(3,702 Views)
Try the attached VI.
George Zou
George Zou
Message 4 of 8
(3,694 Views)
is it possible to  make our digital camera capture images using  labview
Message 5 of 8
(3,399 Views)
Hi 9443972427,
it should be possible. Please see this link for further informations.
Hope it helps.
Mike
Message 6 of 8
(3,394 Views)
thank you very much mike..i need to use a single camera to capture two images and i need to compare them to calculate the distance of a moving object.can u give me a link for learnin the procedure from scratch..my experience in labview is just a week..:(..thanks for the help
Message 7 of 8
(3,390 Views)
Hi BHARATHINDIAN,
you can start with this free online labview courses.
http://www.ni.com/academic/lv_training/d/how_learn_lv.htm
Mike
Message Edited by MikeS81 on 05-21-2008 01:23 PM
Message 8 of 8
(3,384 Views)
