Ignore certain values that are driving a Case Structure
Accepted by Matub
So this is what it should look like.
Tim
GHSP
Message 11 of 13
(639 Views)
Is there a reason you are using Array to Cluster followed by Unbundle by name instead of just using Index Array? It would do away with the Array Subset as well.
I always lean towards using Index Array when I want the first element of an array.
Rob
Message 12 of 13
(628 Views)
Well, Rob, the answer is quite simple.
I tried your suggestion and it works just as well. Thanks for the tip!
_____________________________
Message 13 of 13
(613 Views)
