Idiom for initialising a sub VI?
From documentation for the FOR loop:
The count terminal specifies the number of times to execute the code inside the For Loop. If you wire 0 or a negative number to the count terminal, the loop does not execute.
aputman
Message 11 of 15
(1,406 Views)
Accepted by bojinlund
@bojinlund wrote:
1) I am trying to understand the difference in “my” and “the common” way to initialise a sub VI.
Your way works.  I've just never seen it done that way before.  Perhaps using constructs that people will immediately recognize is worth something to you?
@bojinlund wrote:
Hej GerdW!
Have you any reference to this in the documentation of LabVIEW?
/Bosse
Default Data in Loops
Loops produce default data on the first iteration when the shift register is not initialized.
For Loops produce default data if you wire 0 or a negative number to the count terminal of the For Loop or if you wire an empty array to the For Loop as an input with auto-indexing enabled. The loop does not execute, and any output tunnel with auto-indexing disabled contains the default value for the tunnel data type. Use shift registers to transfer values through a loop regardless of whether the loop executes.
from - http://zone.ni.com/reference/en-XX/help/371361G-01/lvconcepts/for_loop_and_while_loop_structures/
Jim
Message 12 of 15
(1,406 Views)
Betelgeuse
Betelgeuse
Betelgeuse
Jim
Message 14 of 15
(1,393 Views)
Hoovahgeuse
Hoovahgeuse
Hoovahgeuse
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 15
(1,355 Views)
