Identifying CRIO-Module
There is a way to make Labiew recognize which C-module are in my CRIO platform, without using MAX?
(3,412 Views)
You cannot recognize C-seires módules present in cRIO system using MAX, only in LabVIEW Project.
The following link is a Getting Starter Guide for cRIO with LabVIEW.
http://www.ni.com/pdf/manuals/372596b.pdf
Best Regards,
Abel Souza
Applications Engineering
National Instruments Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,388 Views)
Sorry, that´s what I meant.
Anyway, I wanted to make a VI to configure my C-Rio without creating a new project. Is that a way to do that?
(3,368 Views)
No, to use a cRIO Sysytem you need use a LabVIEW Project.
Abel Souza
(3,364 Views)
Accepted by MarcusBianchi
You can read the CRIO module information using CRI library.
Below is the link to library:
http://zone.ni.com/devzone/cda/epd/p/id/1717
Nanda
(3,357 Views)
