Icon Library XML File Location?
My installed version of LabVIEW 2015, Full, SP1, does not have glyphs/icons available, so I am trying to download the required files.  I have downloaded the zip file successfully, but when I try to download the XML file, the link takes me to a page with raw code.  When I copy, paste and save this code into an XML file, I get an error when I try to sync manually.  Syncing automatically also fails.
Here is the location of the xml file that does not work after being cut and pasted: http://www.ni.com/swf/iconlib/icons_filtered.xml
Anyone know where I can find an XML file that will work?
Of course, if there is a better way to get my glyphs working, please let me know.
Thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(8,942 Views)
Right-click on the link to the XML file and do a "Save Link As".  That should allow you to save the XML file to your harddrive.
(8,927 Views)
It's funny.  I tried right-clicking the link on the NI page, but the "Save Link" option did not come up.  When I right click on the link I posted, which I cut and pasted from the web page with the XML file, it works fine.  Thanks!
Forbes Black
(8,910 Views)
So now I have the XML file working correctly, and when I go through the manual sync I end up with the attached screen.  But then when I exit, I still don't have any glyphs.  What am I not doing?  Thanks.Sync Screen.png
Forbes Black
(8,907 Views)
Accepted by diarmaede
So a couple of things might be going on.  Does this computer have multiple users?  Glyphs are installed for the user that installs LabVIEW, but no others.  If you don't like this design you should go vote for this idea.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Shared-Icon-Editor-Glyphs-Directory/idi-p/3253351
As for the broken glyph updating tool, I have no idea.  The stupid thing just has never worked for me.  NI even made a stand alone program once for updating glyphs and it just doesn't seem to work well either.  To help with this I've attached my glyphs and you can just copy and past them in your <My Documents>\LabVIEW Data\Glphys folder.  In addition to the ones that come with LabVIEW 2015 I've also added a Hooovahh folder with several from an open library of icons, and a few I've made.  After copying them relaunch LabVIEW and open the icon editor, then wait a few seconds while it indexes that directory of icons.
Given some time I bet someone could make a tool that properly syncs, downloads, and installs the icons properly, especially since I think most of the icon editor is open source.
(8,859 Views)
Thanks very much!
Forbes Black
(8,842 Views)
Thanks!
(5,266 Views)
