IVI driver session In MAX
I am confused with IVI drivers. I have two IVI drivers for the same instrument( one of them is newer). When I install the older one, I can see a driver session under drivers session category in MAX but when I install the new one, I do not have drivers session for the instrument in MAX. what is the problem?
Ela
(3,585 Views)
Can you tell us a little more information about the instrument drivers you are using?  What instrument are they for?  Also, did you get them from ni.com/idnet, or from some other place?  Are they IVI-C or IVI-COM drivers?
-Christina
(3,550 Views)
HI,
That is Dc850W IVI-C driver. I got it from the vendor site
http://www.programmablepower.com/products/XTR/XTR_Downloads.htm
That is power supply, the older version is available in idnet, but it has some problems as well, but at least it works somehow!
Ela
(3,543 Views)
