INSERT A COMBOBOX INTO A TABLE CONTROL
Could you help me introducing a combobox into a table control.
i would like to fix this combo box in all cells of a specific column.
Do you know how to do it?
The idea is similar to the attached picture.
Thanks in advance.
Message 1 of 15
(6,805 Views)
Unfortunately You can not do this in LV .
You can write code that will simulate this for You. For example when You click on a cell ring will be moved to tht cell and clicked.
You can also this wrapper over .net classes:
https://github.com/unipsycho/LabVIEWdotNetDataGrid
Message 2 of 15
(6,803 Views)
I do not know how to do it exactly using code, i have been searching on google and I could not find a solution. how can I prgram on LabView using code? Could yo help me?
Thanks in advance.
Message 3 of 15
(6,742 Views)
You can do it with an XControl.  It's a bit complicated, but I already made one a while ago.
Message 4 of 15
(6,722 Views)
That is WAY cool Paul!
Just drop that XControl on the FP, pop-up to create a pop-up to create an Invoke node >>> Set Selection List
DONE!
Very nice!
Ben
Message 5 of 15
(6,709 Views)
How about switching to array of clusters (with thin edge)? This will impact your code of course.
Message 6 of 15
(6,704 Views)
That is the fastest way known to get proven wrong!  But, Saying "You can't do that with LabVIEW" usually helps the original poster Smiley Very Happy as seen here
"Should be" isn't "Is" -Jay
Message 7 of 15
(6,695 Views)
Not as wrapped up as nice as the X-Control, but I shared this example years ago showing it done with a Numeric.  I had code for a customer I had done with a mix of strings, rings, numerics.
https://forums.ni.com/t5/LabVIEW/Possible-to-have-a-table-control-that-takes-numbers-only/m-p/318497...
The message linked describes what I am doing.  The message after that has an example with the numeric.  The example could be modified for a ring control.
Message 8 of 15
(6,689 Views)
DONE!
Very nice!
Ben
If you don't need to change the lists dynamically, just open the Custom Properties dialog and edit the lists.
Message 9 of 15
(6,685 Views)
I modified that example in the other thread for a ring control.  The example requires a double-click to activate, but you should be able to change to a mouse click if you wish.
Message 10 of 15
(6,673 Views)
