IMAQ not compatible with Labview 2014?
I'm attempting to work with a National Instruments / SuperDroid Robots SD6 ( https://decibel.ni.com/content/docs/DOC-18528 ) Now... Everyting is connecting fine using LabVIEW 2014 with the robotics module with the exception of the camera functionality. When running the provided solutions LabVIEW can not find the IMAQ dependencies.
I checked MAX to be sure that I have the module installed and I can see IMAQ 4.9 and IMAQdx 4.3.5
Checking the bulletin below about the compatibility of IMAQ, it does not have 2014 listed
http://digital.ni.com/public.nsf/allkb/DB928F6D5E9D6B97862579A7006B2850
I specifically need the 2014 version of the Image Processing Module in the link below. The download link says 2013 and during the install process I'm not seeing an option for support for 2014.
http://www.ni.com/gate/gb/GB_EVALTLKTSIGPROC/US
Is there an evaluation version of this software that is compatible with LabVIEW 2014?
(3,779 Views)
Accepted by JasonTraud
I was able to get in touch with an applicaitons engineer and the image processing module I needed is not yet available for LabVIEW 2014. Hence my issue.
(3,741 Views)
Hi JasonTraud,
Yes, that is true. We hope to have it released by end of August by the latest.
Rahul B.
(3,732 Views)
Hi all!
As far as I know the new IMAQ 14.0 driver is available in the NI Device Drivers 2014.08 package.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,675 Views)
I am using win 7-64bit ultimate, i already downloaded VAS_2014 f1. Following NI, this one support for win 7 and labview 2014. But when I installed, I have problem like this:
Unsupported version of National Instruments system component detected
A version of a National Instruments system component that is not supported on this operating system has been detected. You must cancel this installation and uninstall all unsupported National Instruments software before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information.
Please help me!
(3,364 Views)
