IMAQ find edge.vi - proper setting of options
Trying to use IMAQ find edge.vi I still get a weird error saying something about type conflict with typedef "Edge options.ctl". Please see the attached screenshot.
Is it just Labview bug or did I get anything wrong?
Thank you for your help!
Martin Pekar
(3,195 Views)
Accepted by xombox@seznam.cz
You need to modify the element order in your cluster constant that connects to IMAQ Find Edge. The way you would do this is to right-click on the border of the cluster constant and click 'Reorder Clusters in Control...'. If you want to know what you need to order to, use another IMAQ Find Edge, create a constant for the Options input and repeate the steps that I mentioned to see how the elements in the cluster have been ordered in that constant.
Modifying Cluster Element Order
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,188 Views)
Yes, it worked. Thank you. I didnt know it is so easy to create those constants.
(3,180 Views)
