IMAQ WindSetROI causing crash
I keep having pesky crashes of my application. About one per day. It might be related to IMAQ WindSetROI.  I get the error:
LabVIEW An exception occurred within the external code called by a call library node. This might have corrupted LabVIEW's memory. Save any work to a new location and restart LabVIEW.
VI (my main vi) was stopped at node 0x9C of subvi "IMAQ WindSetROI"
I am deleting all of my IMAQ images, closing vi references and everything before I close the application. This has been dogging me for quite a while.
Paul
PaulG.
Retired
(2,563 Views)
Hello Paul,
I searched for known issues with the WindSetROI functions, but I was not able to find any.
What versions of LabVIEW and Vision are you using?  Can you reproduce the crash with a simple program that reads an image in from file and sets the ROI in a loop?  If not, can you strip down the application to the bare minimum that reproduces the crash (remove everything not related to the crash)?  If you can get your app small enough, I should be able to run it here and try to reproduce the issue.
Either way, let me know so I can continue to help you out.
Best Regards,
Jesse D.
Applications Engineering
(2,557 Views)
