IMAQ USB on Windows Vista
Message 21 of 25
(1,779 Views)
Hi Wes P Sir,
I am getting the same error code on a XP system.  I developed a IMAQ USB application on a XP SP2 box with LV8.5 and Vision 8.5/Vision Assistant 8.5.  I has installed the application on the target machine.  I also had to manually copy the IMAQDirectShowDLL.dlls/IMAQDirectShowExport.dll to windows/system32 to make it run (regsvr32 C:\WINDOWS\system32\ImaqDirectShowExport.dll). I also re-install Vision 8.5 for LV Support  and imaq_usb_installer_setup.exe (version:1.2.0). ths same are Unfortunately the IMAQ Init function returns the same "Minimum Coverage error as reported above".  The same USB Camera can't work in the Vision Assistant, why?! pls refer to the attached files as below:
owen wan
Message 22 of 25
(1,777 Views)
Does your camera work in Measurement and Automation Explorer (MAX)? Do you get any errors in MAX? How is your camera configured in MAX?
Vince M
Message 23 of 25
(1,743 Views)
My Camera work in NI Vision Assistant 8.5, Not MAX!
owen wan
Message 24 of 25
(1,736 Views)
What camera are you using?  Does is use DirectShow filter? Which version of XP do you have?
Vince M
Message 25 of 25
(1,713 Views)
