how to make an instrument driver appear in toolbox
i created an instrument driver using the create new instrument driver project option.  I have all the VIs in place in the project and have saved the whole thing, library and all into the instr.lib folder and have restarted labview and the VIs are still not showing up under instrument i/o -> instrument drivers option.  could someone please go over the process or just tell me what i might be missing to have these drivers show up in the toolbox!
Thanks for help,
brent schenk
(3,344 Views)
What version of LabVIEW are you using?
(3,315 Views)
sorry i should have posted that with the original message but im using labview 8.5
(3,308 Views)
Accepted by topic author BrentSchenk
From the Getting Started Menu >> Browse
From the Create New window >> project >> project from wizard >> Instrument driver project
select New driver from template
select the type of instrument you have
Click next
**Make sure the project location is correct. I think this is where you are going wrong.**
It should say something like, C://Program Files/National Instruments/LabVIEW 8.5/instr.llb/yourproject/yourproject.lvproj
If you have this directory correct, it should show up under the instrument library
(3,291 Views)
