IMAQ PCI 1411 doesn't show images...
I'm trying to capture images with a SENTECH STC-630AS camara.
Camara outputs an NTSC signal which I believe is compatible with the
1411. When I try to use the S-video connection, I get the error:
" Can't lock on video source"
When I use the BNC cable, I get no error when I try to snap an image,
but I get no picture either.
Will these two not work with each other or am I missing some setting
etc ?
Thanks very much !
Rick B.
(2,973 Views)
Hi there,
did you choose NTSC in MAX?
Are you able to see pictures in MAX?
Is the camera working well?
Greets
Matthias
(2,973 Views)
On Thu, 23 Jan 2003 23:44:51 +0100, "M.Waschk"
wrote:
>Hi there,
Yes
No
Yes, it also feeds to a standard NTSC (TV) Monitor and the images are
perfect on that.
Thanks.
Rick B.
(2,973 Views)
I am writing my Labview software and using a PCI 1411 card (no Vision module). I have configured my card in MAX. However, I am delivering the target system to a customer who does not want to purchase Labview, so I was going to wrap it up in AppBuilder as an executable. How do I configure the target system programmatically for NTSC and other parameters without having MAX onboard the target system? Or, if I run AppBuilder, does it wrap up the configuration information from MAX into the executable - and therefore, I wouldn't have to do it programmatically?
Thanks so much for your help. I'm supposed to deliver in two weeks, so I've got a crazy deadline going. I appreciate any help you can give me.
Mary Frey
(2,973 Views)
