IMAQ ImageToArray VI I16 ouput stop working
Has anyone encountered problem with the IMAQ ImageToArray VI such that the I16 output stop working suddenly. The U16 is working fine though.
(3,095 Views)
Accepted by sp@davis
Could you elaborate a bit on your problem? Did you previously have the IMAQ ImageToArray VI working with an I16 output, but now it no longer works? Is there a broken wire coming from the output? What changes were made since it was working? This information should help us hone in on the issue. In the meantime I found a forum pertaining to a similar issue (http://forums.ni.com/t5/LabVIEW/IMAQ-quot-image-to-array-quot-directly-wired-to-quot-array-to/td-p/2...). Have a great day!
Kale W.
Applications Engineer
support@ni.com
(3,050 Views)
Hi Kale, the issue has been resolved. I think it may be due to some recent IMAQ updates and the camera is not very well-supported by NI.
(3,029 Views)
