IMAQ ArrayToImage 16bit
I am trying to convert an array of 16bit monochrome data to an Image with IMAQ ArrayToImage.
When i wire my array to the 16 bit input the VI returns an empty image. The same data wired to the 8 bit input returns the correct image but with only displaying half of the intensity range correct. Why is there now image returned when i wire my data to 16 bit input? (same for the float input)
I am using LabView + Vision Version 8.5 and IMAQ Version is 3.8.0
(2,933 Views)
It's easy for me if you post your current vi. Could you?
Software developer
www.mcm-electronics.com
PORTUGAL
(2,918 Views)
Did you wire an image of the type I16 to "IMAQ ArrayToImage"?
If not, you usually get an empty image.
Regards, Guenter
(2,906 Views)
Thanks Guenter, the image type i used wat U8. With I16 image type everything works fine.
Best regards, Christoph
(2,890 Views)
