IEEE write converted from C
Hello all.  Forgive me for the somewhat basic question, but I'm trying to control an old magnet control gaussmeter (Varian FR41) and the old C code looks like this:
  long  temp;
  int   z1,z2,z3,z4,b1,b2,b3;
  float b;
  double gauss,hv=9555.,magconst=.069,Mass=171.;
  if (ieeeinit()==-1)
    printf("Cannot initialize IEEE system.\n");
    exit(1);
  gauss=sqrt(Mass*hv/magconst);
  temp=10*gauss;
  b=temp/10.;
  z1=b/1000;
  z2=b/100;
  z3=b/10;
  z4=b;
  printf("\n\r %f %f %d %d %d %d",gauss,b,z1,z2,z3,z4);
  b1=z2+z1*6;
  b2=z4+6*z3-160*z2;
  b3=(b-z4)*160+14;
  printf("\n\r %d %d %d %d",7,b1,b2,b3);
  ieeewt("output 08;");
  ieeeprtf("%c%c%c%c\n",7,b1,b2,b3);
I'm having trouble with the conversion to LabView in two areas.  First, the in the line
b=temp/10.;
I do not know how to reproduce the "." element selection in LabView.
Lastly, I can't seem to get the
to communicate with the instrument using the GPIB Send Message.vi.  Is there another solution to sending characters to the instrument through the GPIB hub?
Jesse
(3,137 Views)
Hi RW,
10. ist just a float value of 10...
You can/should replace those old gpib functions by Visa calls.
(3,110 Views)
Thanks for the reply, but I'm afraid I still don't follow (again, new to LabView).  Can you give me some specific examples to help me out?
Jesse
(3,104 Views)
Accepted by topic author RWCarlson
It would look something like this..
You'll need NI-VISA installed on your PC.
You'll want to get the format of your command string right (see manual).
If I were you I would also look up how to query the Varian for errors, then send that command to it and read the response.  For that you would issue a VISA write, delay say 1s, VISA read.
Craig
(3,082 Views)
