IEEE 11073 32bit float format
How to convert 32bit hex number to IEEE 11073 32bit float format?
Message 1 of 15
(12,520 Views)
I think you mean IEEE 754.
Can you show us what you have tried thus far?
Message 2 of 15
(12,495 Views)
Thanks tyk007,
No, I ment IEEE 11073 32bit float format.
I found the way, actually in IEEE 11073 ( 1st byte is Exponential (10 pow 1st byte) and rest 3 bytes are mantissa).
Message 3 of 15
(12,476 Views)
Hi kiran,
please check for yourself: Wikipedia IEEE 11073
When you want to convert to a base10 32bit float you need to find a library which suports this conversion (use Google or any other search engine) - or use some bit-banging to program this conversion on your own…
When you already created a VI for this conversion: please attach it here for future reference!
Message 4 of 15
(12,456 Views)
No sign bit?
Message 5 of 15
(12,442 Views)
Thanks GerdW for the link.
I have attached what fitts to my solution. There could be number of way.
The attached VI requires Hex array passed, will give you Temperature in Celsius. I believe even signed value is taken care.
Note: 4 Byte Array(Hex) would be in BigEndien IEEE 11073 . i.e  value of 24.25 would be 79 09 00 FE
Let me know if there is any problem in it.
Message 6 of 15
(12,391 Views)
Hi Kiran,
can you attach your VI for LV2014?
How are Base10 floats related to IEEE11073? Wikipedia doesn't mention them (when reading the article rather quickly)!
Message 7 of 15
(12,367 Views)
Stackoverflow has a thread regarding the conversion of 11073 to a java float -
http://stackoverflow.com/questions/11564270/how-to-convert-ieee-11073-16-bit-sfloat-to-simple-float-...
Message 8 of 15
(12,352 Views)
Your code is not 100% correct. It works fine for positive numbers. BUT the mantissa is a 24bit signed integer. You are converting the mantissa string to a U32 integer and ignoring the sign bit in the string. This c-code came from the "STACKOVERFLOW" thread that PhillipBrooks mentioned. It is the conversion for a 12 bit integer. However, you can easily change the constants for a 24 bit conversion.
Message 9 of 15
(12,330 Views)
Accepted by kiran.holla
Hi Kiran,
Well, I found a problem of using too much unneeded datatype conversions!
Is there a reason you need to convert U8 values to strings to be able to build other integer and DBL values from them?
Why not something simple like this:
The other case holds your version of this code…
(The shown code can be simplified even further, I just replaced your U8-to-string-to-U32 dance…)
Remark: both code version give the same result.
None give the result you expect according to your own statement:
So I guess there are other problems too in your VI…
Message 10 of 15
(12,311 Views)
