I want to multiply two arrays
but one of them is analoge that's why it multiply the first array to the first value of the second array
(3,764 Views)
Accepted by topic author hussamwakeel
There is only one multiplication involving an array on your block diagram, and it does not involve two arrays, it involves an array and a waveform.  Is this what you are referring to?
You can use an In Place Element Structure with a Waveform Unbundle / Bundle Elements node to unbundle the Y array component of your waveform, then multiply it with your array, then bundle the result as the new Y array component.
(3,752 Views)
Do you want an array out of a waveform?  If just an array, use the Get Waveform Component to get the Y portion of the waveform and multiply with that array.
(3,737 Views)
