I need help export table excel
The states
1 - Idle
2 - Pump On, Generate New File and Record
3 - Pump On and Stop Recording.
4 - Turn Off Pump, Continue Recording.
5 - Turn Off Pump and Stop Recording.
Files cannot overwrite each other. When the pump button returns to TRUE, the pump must generate a new file.
It can go
1 to 2
1 to 3
2 to 3
2 to 4
2 to 5
3 to 4
3 to 5
4 to 5
Message 11 of 19
(535 Views)
Thank's
Vou testar assim que chegar em casa, nesse caso aí eu consigo fazer para as 5 variaveis e consigo também colocar para exportar em uma planilha em excel?
I'll test it as soon as I get home. In that case, can I do it for the 5 variables and can I also export it to an Excel spreadsheet?
Message 12 of 19
(534 Views)
@Felipe_Alves17 wrote:
The states
1 - Idle
It can go
1 to 2
1 to 3
2 to 3
2 to 4
2 to 5
3 to 4
3 to 5
4 to 5
See, now you just need a simple state machine!
Message 13 of 19
(523 Views)
My friend, thank you so much. I'll send you the VI. I just added mine and made the connections. I was following ChatGPT, and it was telling me to create a Case Event, which was making things more complicated than helping. But the solution you gave is very simple and straightforward. I'll send you the VI I made based on yours, and it's working perfectly.
Message 14 of 19
(512 Views)
Accepted by topic author Felipe_Alves17
Hi Felipe,
You really should take some beginner lessons to create more "LabVIEW-like" code!
See this:
  • Avoid repeating code when you can use an autoindexing FOR loop…
  • I prefer outputs being set instantly (pump/recording ON) instead of waiting for the next iteration…
Btw. when attaching VIs you should rename them instead of pretending "modifications by CA" by still using the "_MODCA" in the filename!
Message 15 of 19
(487 Views)
Thank you very much, I will have to learn a lot of things indeed. I liked the way you used the FOR loop, my concern was whether the columns in the spreadsheet would come out with the names of each variable, since I was inserting the name by double-clicking on each block in signal name.I will test it the way you showed, it makes the code much simpler. Do you have any tips to improve my programming method and to use conditionals in the best way?
Message 16 of 19
(474 Views)
Personally, I would even use an array of strings instead of scalar string followed by built array. Fewer cats to herd... 😄
Message 17 of 19
(459 Views)
It turned out really well. Besides reducing visual pollution, it also improves PLC monitoring, as you mentioned. Thank you very much! I'm currently facing an hour meter challenge. Turn on the pump and start counting the pump's operating hours, write the file, and then read the file, as you'll need to turn off the PLC and monitor the engine's operating hours.
Message 18 of 19
(374 Views)
Hi Felipe,
You're not the first to ask for such algorithms…
  • Store the "hour meter" data in a file.
  • Load the file content on program start.
  • Count up the "hour meter" data as long as the program runs (based on conditions like "pump on").
  • Store the data to file upon program cleanup/exit. (I recommend to store data more often while the program runs to prevent data loss on failure.)
Message 19 of 19
(366 Views)
