I must go from string to 2 16 bit integers.
Hay,
I have problem with data types.
I m starting from a string and I must go to 2 times a 16 bit integer.
In the string I type a number like this 5,87.
I made an example to make it clear.
I hope someone can help my because i need soon a solution.
greetz Rutte
(2,767 Views)
Accepted by topic author Modbus probleem
Add a SGL diagram constant as default, else you get DBL.
(2,764 Views)
I didn't now it was so simple.
(2,740 Views)
