How to read particular pin data in Labview
I am using PCI NI-1426 frame grabber to capture the images at particular frame rate. Ni-1426 has 2 ports i.e. 26 pin camera and 15 pin triggering port. I am sending the pulse per second (pps) signal from gps to the triggering port. I want to check for the pps signal through the frame grabber 15 pin port. Please tell me how can I listen to a trigger through a frame grabber in labview? or how can I read a particular  pin data in labview.
Sidd
(3,084 Views)
Hi Sidd,
You should check out the Example Finder under Hardware Input and Output»IMAQ»Signal Input and Output for examples of triggering in framegrabbers.
Stephen Meserve
(3,036 Views)
