I have created an installer using lv8 .For demo purpose i want to run this for a fixed number of days.
hi all
Iam using LabView8.I have created an installer using lv8 .For demo purpose i want to run this installer for fixed number of days such that it should run only in that duration of time or else not.
cheers
jays
(3,600 Views)
Hi Jays,
you cannot limit the installer to run only on certain dates.
But you can limit the lifetime of your app by using something like this:
- count number of executions
- check system time
- check accurate time by internet (if available)
- save those values in (hidden) files or registry keys
- use a password to limit users/lifetime
You can do all this in software - but you have to make your own thoughts on this...
(3,586 Views)
Hi Jays,
just a crosslink to a (very) similar thread Smiley Wink
(3,580 Views)
hi
thnx for the hints..........
but when u take system time into consideration the application will start running when u change the system time to the past.--rt?
limiting no. of iterations looks  simple but i want my installer to be rich at the same time i dont know how to use the register keys or internet time to consider.
can any one post a replySmiley Wink
thnx in advance
(3,570 Views)
Hi jays,
some comments:
"when u change the system time": to protect software from misuse is always complicated Smiley Wink Make some complicated algorithm Smiley Wink
i dont know how to use the register keys or internet time":
-registry keys: there are examples coming with LabView!
-internet time: look for NTP in the forum! (maybe here?)
Hey, you want to protect your software, so you have to write some protection routines.
Or ask a software consultant and buy those routines... There are also hardware solutions available - at a reasonable price Smiley Very Happy
(3,560 Views)
GerW,
Nice, that you ve made a crosslink for both the posts. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(3,552 Views)
