How can I write data to table row by row?
Hey, I have some data need to process,also need to display to user,4 different kind of data I grouped them together as a row ,I need to process these data row by row,How can I write data to table row by row to assiste my process?
Means, how to put "1d array" data into table in order?
Thanks.
Cheers,
Nicosg
anico2127@yahoo.com.sg
(5,002 Views)
Hi Nicosg,
are you talking about a table or a 2D-array of numbers? A table is just a 2D-array of strings...
General answer: you have to build a 2D-array from your 4 sets of 1D-data by simply using "build array" function!
Or, more complicated: initialize a 2D-array and fill the data into the proper cells by using "replace array element".
Message Edited by GerdW on 09-20-2007 11:05 AM
(4,994 Views)
Use Invode Node to call the "Set Cell Value" Method of the table. It takes 3 Parameters, row no, col no and data string.
Check the attached VI.
Best regards
Siva
sivamgr@gmail.com
(4,989 Views)
Nicosg
as Gerdw said, you better use a 2D array.
maybe you want to post your vi, so we can see what you really mean?
... And here's where I keep assorted lengths of wires...
(4,985 Views)
hi,
just insert ur data in table using inser into array vi. by specifing the index.
Message Edited by Ranjeeta on 09-20-2007 05:40 AM
(4,971 Views)
