I have both LV8.6 and lv9.0. When I'm running 8.6 I have DAQmx, but in LV9.0 I do not have it. How can I get DAQmx in 9.0 also?
Thank you
Message 1 of 9
(3,327 Views)
Accepted by topic author chuck72352
Did you reinstall the DAQmx drivers after installing LV 2009?
Message 2 of 9
(3,326 Views)
I loaded the NI Developer Suite, figuring it was there. I guess I was wrong. Do you know off-hand where I can download it from?
Thank you
Message 3 of 9
(3,317 Views)
I found the driver and downloaded it. Thank you for your help!
Message 4 of 9
(3,312 Views)
It is a separate DVD with the Developer Suite that says device drivers.
Message 5 of 9
(3,311 Views)
I reloaded the "NI Device Driver DVD" (Feb 2009) and I still dont have DAQMX for LV9.0, but as before only for LV8.6.
Message 6 of 9
(3,288 Views)
LabVIEW 2009 (9.0) didn't come out until August 2009, so the Feb 2009 device driver DVD won't have the DAQmx designed for it.  You need to use the Device Driver DVD that came out with your LabVIEW 2009.  Or download the latest driver from here. DAQmx 9.1.1
Message 7 of 9
(3,283 Views)
That's not the one that came with LabVIEW 2009. You need the driver DVD that came with that in order to get a compatible version. You could also just download the latest.
Message 8 of 9
(3,282 Views)
Once I downloaded the right drivers everything worked fine.
Thank you,
Message 9 of 9
(3,242 Views)
