I have a question about image filters
If you don't speak English, use Google Translate. Thank you for your understanding.
I made a small device and scanned the product, and it is expressed in the image to see if shaking occurs in a specific part.
Is there a way to use an image filter to erase an existing image without distorting it??
Thanks a lot for your advice. 😄
(1,076 Views)
You have to explain that a bit more.
"Erase an existing image without distorting it" just isn't clear enough to give sensible advice.
(1,042 Views)
I want to erase only the red part of the attached image.
If you use the 1st step of the N-order filter, it will be erased, but it will be artificially changed to other parts and become an unusable image.
Is there any other way?
(1,007 Views)
