I get the error code 87 with System Exec VI
I need to launch a program (vibrometra) from labview. In the attached image it is possible to see the command line that I am using. In the path i am specifying the location of the executable file.
I have checked that it is possible to open vibrometra program using this path with the "Run" window..
So I don't know what should I write in the command field..
Thanks in advance for your help!
(6,429 Views)
Is that error a LabVIEW error or an error in the system exec window?  The LabVIEW error 87 is a variant conversion error, which does not make since to me.
(6,412 Views)
Accepted by jess1006
Do you have a space in cmd/k (correct: cmd /k)? Though without space LV2011 gives me error 2, not 87
Also do you need to open command window (cmd)? I usually specify full path (path and exe name) as a command, no problem. Working directory is not requred then.
Edit: Full path in quotes not to have problems with spaces
"C:\Program Files\prog\prog.exe"
(6,392 Views)
It was an error coming from labview. I am able to actually launch the program writing exactly the same full path in the command field (including file.exe).
Thanks very much for your help!
(6,372 Views)
