キャンセル
次の結果を表示
次の代わりに検索
もしかして:
I controller (based on a PID controller) in Labview vs PID in Simulink
解決済み
解決策を見る
Good day,
Was checking the forum trying to find something similar but came across only a couple of topics that were not helpful.
I need to design an I-controller (from a PID block) to implement in hardware my Matlab/Simulink code. In one of the older threads I noticed that the current PID block (in 2012) did not allow to use only an integral part (when P=0). On top of that, the PID implementation in Labview and Simulink is a little bit different. The standard PID block in Simulink does not require to have a set-point port (even though it is possible to implement). Whereas in Labview, this port is presented by default in all possible PID variations.
So now I stuck the PID controller that can’t operate as an I-controller. Since this PID controller works with two different systems, it is impossible to have any set-points as the input. Already not the best start. A couple of other differences that I’ve noticed trying to tackle this issue.
Simulink PID controller (the as in the C&S toolkit http://www.ni.com/white-paper/6440/en/) based on the PID gains K-coefficients. The Simulink controller is defined by the proportional K-gain and time constants for the integral and derivative inputs (https://www.ni.com/en/shop/labview/pid-theory-explained.html).
I am more than aware about the use of the Standard PID controller in Labview (with P and I components), but this I-controller makes my tasks are quite challenging (even though the controller is more straightforward). I’ve tried to simulate a PID controller in a Mathscript node as a transfer function, but it is hard to judge how correct its behavior.
Does anybody know what can be done to solve this issue? Thank you.
0 件の賞賛
メッセージ1/6
4,885件の閲覧回数
Hi Michael,
can't you create a copy of the PID function coming with LabVIEW and rework that copy to implement your "I-controller"?
Or implement that algorithm in a fresh vi?
What's the point of a controller when you don't have a setpoint?
(How does the I part calculates and integrates the error, which usually is defined as difference of pv and sp?)
0 件の賞賛
メッセージ2/6
4,882件の閲覧回数
解決策
受理者 MichaelAsh
It's been a while since I looked at Simulink, but I believe it accepts the error (rather than a setpoint and process variable) as the input, and tries to drive that error to 0.
To implement a pure integrator controller, I would use the Integral x(t) PtByPt function (point-by-point integration). Integrate the error and multiply by the desired gain.
0 件の賞賛
メッセージ3/6
4,864件の閲覧回数
Hi nathand,
Yep exactly what I did after I had a look at the code again. So obvious. I've tested it over the last day or two and found perfectly suitable for my application. Cheers.
GerdW,
Yeah it is doable, but I was looking for smth less bulky than the standard PID block (since I needed only the integral part). Thank you for your tips.
0 件の賞賛
メッセージ4/6
4,835件の閲覧回数
what r the advantages of PI controller in labview compared to matlab for switch reluctance motor
0 件の賞賛
メッセージ5/6
4,216件の閲覧回数
Hi padmashree,
what r
See this excellent thread
As long as the same implementations are used there will be no advantage…
A PI controller is a PI controller, no matter which programming IDE is used!
0 件の賞賛
メッセージ6/6
4,210件の閲覧回数
