I cannot save the numeric values in the array
When I close the program and start it again, all the values in the array are initialized to zero. I want to have the same previous values that I entered before in the array.
Thanks for your help!
(2,997 Views)
Then you need to write code to save the values in the array to a file when your code exits, and read them from that file when it starts.
(2,993 Views)
Accepted by Ven1
If you always want the same values at the beginning, just enter all the values in the controls, the do "edit...make current values default". Save the VI.
(2,987 Views)
It worked! Thanks so much for the help.
(2,983 Views)
