I can't read my exact float value in modbus communication
hello,
I am using Multi function meter RS485 communication. i can read the floating address. but i can't read full floating address like 128. need full address like 128.23(after point decimals).
In modbus tool kit it able to read full register. but, In labview i not able to read full register.
Message 1 of 19
(6,266 Views)
Hi Balaji,
what have you tried so far?
Why don't you attach your VI?
Which if the data bytes in your image do you want to convert to float?
Which device are you using?
What does the manual of that device mention about your float value?
(Come on: provide some useful information so we will be able to help you…)
Message 2 of 19
(6,230 Views)
It could be a decimal separator issue.
If your app is using the comma (,) as a decimal separator... this is a Windows regional setting, but you can forece LabVIEW to ignore the OS settings and use the dot (.)
LabVIEW >> Tools >> Options... >> disable the option "use localized decimal point" (second option from the top in the "Front Panel section)
Epictetus
Antoine Chalons
Message 3 of 19
(6,221 Views)
The last time I dealt with MODBUS values like this were always sent as an Integer then you had to scale it to a float.
For instance if I asked for the voltage on L1 it would return 12823
I would then have to take that integer and divide by 100 to get the 128.23
=== Engineer Ambiguously ===
Message 4 of 19
(6,189 Views)
If the instructions on how to handle the incoming data can't be found in the manual, they probably want you to buy the SDK.  😉
That being said, without showing us the code and without the manual, you're pretty much on your own.  We can't really help much.
Bill
CLD
(Mid-Level minion.)
Message 5 of 19
(6,172 Views)
IIRC, Modbus doesn't have a specification for floats.
So, everybody makes up things.
Sometimes, integers needs to be scaled. That's easy, simply divide by x.
Sometimes 4 bytes need to be cast into a single. This can be done in quite a few ways. My device used Modican protocol, but other devices have the two addresses switched, but not the byte order, other have both swapped. IIRC, Modicon and Motorola where at least two of the variations.
If you have the bytes of the one or two registers, and a known value, I'm sure we can figure it out.
Message 6 of 19
(6,143 Views)
Thanks for reply,
1. I tried to change the data type to float or long.
2. i attached my VI.
3. All 6 values.
4. multi function meter model no RISH LM1360 and Rs485 to Usb converter.
5. default data type float.
Message 7 of 19
(6,118 Views)
Thanks for reply,
but, no change  same issue.
Message 8 of 19
(6,113 Views)
Accepted by topic author Balaji_dm
If you wire a U16 to a double or single, the value simply gets converted. That's might not be what you need. You get bytes that represent a float, but they are communicated as 16 bit numbers (2 bytes).
You probably need to combine two U16s, with a Join Number for instance, and then Type Cast it to a single (4 bytes). Bytes might need swapping, the words might need swapping. you might even need to combine 4 U16s to make a double (8 bytes).
Changing the type to float does not magically turn a I16\U16 into a float. You need to make that happen.
Message 9 of 19
(6,105 Views)
@Balaji_dm wrote:
Thanks for reply,
You didn't attach any example as to what your bytes are and what you expect the result to be!
Message 10 of 19
(6,083 Views)
