03-22-2021 04:20 AM
I wanted to update from 2019 labview to 2020, so i removed old software and tried to download the new one. now i get this "error: an error when launching the following required file: 'GUIExecutableFullPath'. The installer might be corrupted . try redownloading or using new media distribution. " does someone know how to fix this?
03-22-2021 04:44 AM
How did you "remove old software"? If you used NIPM to remove it (as you would have if you used Windows "Add/Remove Programs and Features"), and "did it correctly" (as has been documented in these Forums and by doing a Web search for "Safely remove LabVIEW"), you should be able to install LabVIEW.
If, however, you have used Registry-editing tools to "forceably" remove LabVIEW, the only way I (and others) have found to fix this problem is to backup your system, wipe the hard drive, reinstall Windows and all other installed software, then reinstall LabVIEW.
Unfortunately, as LabVIEW has grown in size and complexity, it has become more challenging to install. Again, suggestions for how to overcome some of these difficulties have been documented here in the Forums and on the Web.
05-06-2021 06:24 AM
I have fixed it a long time ago, just had to delete a lot of hidden files. I don't recommend wiping the hard drive that's just lazy advice
07-12-2021 02:19 PM
Hi, can you tell me the path of hidden files? I have dame issue. Thank you
07-13-2021 05:24 AM
Depending on how long "a long time ago" is, that method may "long ago" have expired too. LabVIEW itself is seldom the real problem. That is still fairly contained. But once you start to install DAQmx and many other things that add actual kernel mode drivers, just deleting hidden files will nowadays rather cause your system to blue screen or cause other undesired effects than get your system cleaned.
07-13-2021 01:22 PM
It's not lazy advice. You should read all of Bob's posts regarding installation disasters using NIPM.
07-28-2022 07:04 AM
One case I had is the NIPM window (starting already for uninstalling) was cancelled accidentally. You can't not reinstall a new NIPM due to the path error. Try this
1. run cmd and run command
C:\Program Files (x86)\National Instruments\Shared\NIUninstaller>uninst.exe /NoNIPM
2. if a NI installation window pops up, try to uninstall package manager related items (such asn NI Package manager support, NI Package manager COre).
3. Try to re-install a new NIPM (no reboot needed).
End
07-29-2022 08:57 PM
In 2017, the first year NIPM was introduced, I messed up two perfectly-good PCs running Windows 10 and (if memory serves) happily running LabVIEW 2014, 2015, and 2016. Here was the method I used to repair both machines:
It took me 2-3 days to carry out such a "recovery". I only did it after spending a week or two trying other "fixes" that seemed to make things go worse. Your mileage may vary ...
08-01-2022 01:07 PM
Another potential solution for a damaged NIPM install is just to install the latest version from ni.com here (new version released a few weeks ago). It's not that you're hoping for NIPM fixing some bug that is causing a problem, but instead that a new NIPM version does a clean install of itself, which can solve numerous problems.
09-04-2024 08:24 AM
Late to the game here but WesW's suggestion of downloading the latest version of Package Installer (24.5.0) works.
Don't need to wipe your OS.
