I can't found a function
Hi ,
sorry for that noob question ;I m new with Lab view ,
My friend just give me this , for i can use it on my own porject , he totaly forgot all about labview
now i m alone with it  and i want your help
simple and noob question : i can't found this function in th picture below
sorry for my bad english
(3,519 Views)
Accepted by YozBoy
Hello YozBoy,
That function name is Bundle.
Navigate steps.
1. Right click on the block diagram, to activate function palette.
2.Navigate to cluster, class and variant subpalette.
3. There you will find the Bundle function.
Hemant
(3,504 Views)
Accepted by YozBoy
But I recommend using Bundle By Name (same location in the palettes) since it is more self-documenting.
(3,487 Views)
Correct bundle by name is more self documenting function.
Better if you use bundle by name.
Hemant
(3,479 Views)
Yozboy,
     There are a number of tutorials and self-study paths for LabVIEW, particularly if you are in school.  Look on the first page of the LabVIEW forums, and you can also find things on the Web.  I recommend the tutorials mentioned in the Forums -- you need to spend a little time, but that is true for any programming language (LabVIEW, in my experience, is easier conceptually than many others ...).
(3,458 Views)
