I am recieving an Error code when I try to compile a program to an FPGA chp in a cRIO but I don't know what the code means.
This is the message that I am recieving when I compile to the cRIO I am working with.
FATAL_ERROR:Portability:PortDynamicLib.c:358:1.27 - dll open of library
   <C:/NIFPGA85/Xilinx\bin\nt\libGenXstTask.dll> failed due to an unknown
   reason.   Process will terminate. For more information on this error, please
   consult the Answers Database or open a WebCase with this project attached at
   http://www.xilinx.com/support.
I have no idea what this means.  Thank you in advance for the help.
(2,816 Views)
UtahTiger;
First let me ask a few basic questions
What version of LV are you using?
What OS is your development machine?
When in the compile process does this error occur?
Can you compile other (blank) VI's, id the problem with this particular project?
Have you been able to compile this project before. what changed?
Once I know a little more about your system we can narrow down the source of your error.
Message Edited by Huter on 04-29-2009 04:16 PM
(2,779 Views)
