I am not able to use picture functions(pixmap) in v5.1
Hi
I have Labview 5.1 installed on my PC. I cannot make use of the picture functions under graphics and sound palette.
The functions are not executable, it just shows question marks. What can I do to fix this problem.
Vernon
(2,940 Views)
Hi Vernon,
Most likely your *.mnu file that describes the links to the different VIs in the palettes has been removed or deleted or the actual picture VIs have been moved so the link from the *.mnu file to the VIs is broken. That would result in the question marks in the palette.
The easiest to do to fix this would probably be to reinstall LabVIEW. You are not able to directly edit the vi.lib palette to repair the *.mnu links.
Let me know if this doesn't work.
Have Fun!
by the way - isn't it time to upgrade to 7.1? 😉
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,932 Views)
No.  Wait for 8.0. 😉
George Zou
George Zou
(2,929 Views)
I have absolutely no clue what you are talking about!!!
Thinkbot Solutions
(2,922 Views)
Ya. right.  take a look List 2.
George Zou
(2,914 Views)
Hi Guys
I have upgraded to v7.1 and my problem is sorted out.
Thnx
Vernon
(2,908 Views)
