I am looking for some information on ELAN protocol for Siemens analyzers and also some information on AK protocol for California Analytical Analyzers. Mainly I need a starting point to communicate with these devices for labview.
Willem,
I replied via email.  Please confirm you received the email with attachment.
For support, you may want to reply to this forum thread, many other users of Siemens gas analyzers have used this code to interact with their devices and some probably are subscribed and receive updates.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 251 of 279
(2,262 Views)
Hay David,
I see you have already gotten communication to the Ultramat 23. All I need to do is to communicate to 1 on my system. would your program work on a single unit?
If so could I get a copy of it?
Email russb@alto-shaam.com
Message 252 of 279
(2,206 Views)
What would be a good RS485 cable would be best used?
Message 253 of 279
(2,208 Views)
Russ,
Replied via email.  Please confirm you got a zip archive.
No special cabling.  It tends to be a custom setup, and it really is two signal wires (the TxD/RxD+, and the TxD/RxD-), plus of course a common return wire.  The back of the ULTRAMAT/OXYMAT is a DB9 (I forget the gender).  Your host side interface could be an NI-485 or some other level converter, but it does need to support two-wire mode (meaning the port somehow controls the driver and also blanks the receiver while transmitting).  You likely have to bridge the TxD and RxD pin pairs yourself on your host.  On the Siemens side, it is just a single pair of pins (labeled + and -, or maybe something-P and something-N, again I forget).
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
Message 254 of 279
(2,192 Views)
Hello David,
I am also interested in your library. We have an Ultramat 6.
Could you send it to: serizonAustralia@hotmail.com
Gerard
Message 255 of 279
(2,100 Views)
Gerard,
I sent you a ziparc; please confirm you received it.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
Message 256 of 279
(2,089 Views)
Hi David
I'm Bob
My email is bob.li@engsoft.studio
I asked for your help, too
I am also looking for Ultramat 23 via RS485 communication files
I read from page 1 in 2004 to page 26 in 2022
I didn't find any ZIP or PDF support link in the post
And I was worried that if David retired no one would respond
And I'm so happy to see you replied to the post in 2022
Thanks you for the support over the years
Message 257 of 279
(1,968 Views)
Thanks to Dave and Russ for the replies.
I'm so glad you responded so quickly.
Thanks again.
Below is the ELAN Interface Description file I found.
It might help some friends
ELAN Interface Description PDF
D__ELAN_Description_11_08_en.pdf download at :
The source post
Message 258 of 279
(1,953 Views)
Bob,
You are welcome!  I hope you find the driver and the example application to be helpful.
I think the link you provided directly to the PDF on the Siemens website may only work if one has a logged-in Siemens profile.  At least, that was my experience - only after I logged in (I already had an account) would the site allow access to it.
I need to replace the old (1998) copy of that PDF with your linked one ("new" - 2008!) in the zip archive I send out.  I have had one from 2006 in my possession.  Each release has a few additional commands which seem to only impact the latest models and/or the latest firmwares.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
Message 259 of 279
(1,944 Views)
David,
I am looking to configure an Oxymat 6 for use with LabVIEW and am looking for VIs and/or drivers to get me started.  Any help is much appreciated.
Message 260 of 279
(1,908 Views)
