Hypothesis testing
I want to make a labview application that lets me test between different types of hypothesis, using different kinds of methods, but I have no statistical background and could really use someone's help.
What I want to do is enter the 2 hypothesis in some text boxes, then select a method to test the hypothesis from a text ring, import the data from a csv, and then read which is the correct hypothesis, based on the result.
If someone could please help me, I would be really grateful.
Thanks.
(2,869 Views)
If you have a good statistical background and know the Math that you want to do, there's no harm in using LabVIEW, particularly if you are using it for other "Engineering Workbench" tasks.  However, if you really want "Beginner's Statistics" software, particularly to "do the Math" for you, you are better off with a Statistics package than with LabVIEW, designed for "other things".
(2,851 Views)
Do you know where can I find Labview examples for these vis?
I really need to do this and would really appreciate if someone could help me.
Thanks.
(2,799 Views)
When Your Only Tool Is a Hammer, Every Problem Looks Like a Nail!
Do a Web search for Free Statistical Software and for Statistics Tutorial.  If you don't know what you are doing, using LabVIEW to "not do it properly" won't help you achieve your goal.
(2,786 Views)
