04-22-2008 08:54 AM
04-22-2008 09:01 AM
I'm pretty sure that by deactivate property node you are talking about the Disabled property node but I don't know what you mean by 'option field'.
For a pull down menu item, you can enable/disable it with the Set Menu Item Info function.
04-22-2008 09:01 AM
04-22-2008 09:06 AM
04-22-2008 09:15 AM - edited 04-22-2008 09:16 AM
Really?
@Mathan wrote:Hai,It seems you can only deactivate the whole menu ring(Create 'visible' property node and wire a true constant to it and also in FP right click and select 'disabled' from 'advanced' ) and not a single item in it.
04-22-2008 09:18 AM
04-22-2008 09:19 AM
04-22-2008 09:30 AM - edited 04-22-2008 09:30 AM
11-12-2017 07:08 AM
Thank you
