Hypervisor vs XP
I am developing RT code on a PXI chassis while booted in the Hyperviser Mode and it works fine. I can deploy code to the RT and have GUI windows to display my system etc..
My question is why not just run under Hyperviser and not run under XP at all.
What is the difference between the two (Hyperviser vs XP).
(2,765 Views)
Accepted by CarmineS
Hi CarmineS,
I'm not sure that I understand your question entirely.  Hypervisor is a software package that allows you to run both Windows and LabVIEW Real-Time on the same machine and share resources.  Is your question why you would run Hypervisor instead of just LabVIEW Real-Time?  Some applications require being able to access a UI on a system, which is what Windows provides.  There are lots of reasons to use Hypervisor, but it certainly isn't necessary in every case.  I hope this helps.
(2,735 Views)
