09-29-2020 06:43 AM
I have been trying to install LabVIEW 2020 64-bit, and it keeps getting hung up on the step "Installing LabVIEW Database Connectivity Toolkit (64-bit)". I have nine nearly identical machines, and I get the same issue on all nine. I have tried installing 64-bit :LabVIEW twice now, and the same issue occurs.
I also have LabVIEW 2020 32-bit installed on these machines, and they work fine.
09-29-2020 08:42 AM
If you are not working with really big data structures that require 64-bit memory, why not stick with 32-bit LabVIEW (which, by your own admission, works fine)? Particularly since this problem is reproducible among all your LabVIEW 64-bit installations ...
09-29-2020 08:51 AM
I am a technician at a University in which one of the professors insists on having the 64-bit version of LabVIEW on the machines in his lab. I don't have a choice in the matter.
09-29-2020 08:55 AM
Does said professor understand that LV 64-bit doesn't have the same level of toolkit support as LV 32-bit, and comes with some oddball bugs not present in LV 32-bit?
NI recommends installing LV 32-bit unless data that you are expecting are larger than what a 32-bit application will allow.
09-29-2020 09:04 AM
Yes he is aware. A particular application in which convolutions are performed on large chunks of data from a high speed DAQ is a particular reason in why insists on the 64-bit version of LabVIEW.
09-29-2020 10:47 AM - edited 09-29-2020 10:48 AM
This isn't an answer, but the LabVIEW 2020 Database Connectivity Toolkit Readme describes the LabVIEW Database Connectivity Toolkit, which added support for LV 64-bit for toolkit version 2020.
So, hmmm...
09-30-2020 10:27 AM
I can confirm this issue as well. Is there a workaround?
09-30-2020 11:18 AM
It looks like despite getting hung up during the installation process, LabVIEW 2020 64-bit did install. I haven't tested it exhaustively, but I was able to make a simple VI.
09-30-2020 11:57 AM
That's terrible. 😞
02-14-2021 11:39 PM
hi itoma ,
Did find any solution for this issue?
I tried with lv2020sp1_64 installer still facing the same issue. Tried with db toolkit (64bit) as well but issue remains. In my case also 2020sp1_64 installed successfully but fails at Db toolkit step.
